| Tubeless valve stems http://ducatipaso.org/forum/viewtopic.php?f=1&t=6796 |
| Author: | desmoluci [ Fri Jul 11, 2014 6:57 pm ] |
| Post subject: | Tubeless valve stems |
Hello all, I need to replace my rear valve stem as it is broken. Do the Oscam wheels use a special size, or can I use any standard size replacement? Thanks |
| Author: | Mc tool [ Sat Jul 12, 2014 4:33 am ] |
| Post subject: | Re: Tubeless valve stems |
many of the standard sizes available might fit
| Author: | Derek [ Sat Jul 12, 2014 9:58 am ] |
They come in 8.3mm and 11.3mm sizes to fit the hole in the rim. For a Ducati you need the smaller 8.3mm size. Like these - |
| Author: | desmoluci [ Sat Jul 12, 2014 6:41 pm ] |
Great news, thank you for helping me out. Those were actually the ones I was wanting to get.
| Author: | Mc tool [ Mon Jul 14, 2014 3:27 am ] |
The right angle ones look real good but I found they fouled the front calipers if you have them at 90 deg |
| Author: | lane1feathers [ Mon Jul 14, 2014 3:58 am ] |
I was told by the tyre shop that the right angled ones didn't fit as they weren't long enough for our rims So, for a few dollars, I bought a brass right-angled adaptor valve-extension to screw on when checking tyre pressures. He had some on the counter. I keep it under the seat. Works mint. |
| Author: | Derek [ Mon Jul 14, 2014 9:29 am ] |
| Author: | desmoluci [ Mon Jul 14, 2014 12:34 pm ] |
| Author: | Mc tool [ Tue Jul 15, 2014 5:30 am ] |
| Author: | desmoluci [ Wed Aug 06, 2014 2:25 am ] |
I found these to be a perfect match to the original by a company called K&L and sold through The Motorcycle Superstore. They seem to be good quality, too. http://www.motorcycle-superstore.com/36 ... valve-stem |
