| trick anyone? http://ducatipaso.org/forum/viewtopic.php?f=1&t=6803 |
Page 1 of 2 |
| Author: | Brutus [ Wed Jul 16, 2014 8:55 pm ] |
| Post subject: | trick anyone? |
I've found a good set of 10:1 pistons with matching cilinders. Done approx 14k kilometers. Only problem is I don't know which piston was used in which cilinder. Is there a way to find out? Or is replacing the rings the only solid option? Léon |
| Author: | higgy [ Wed Jul 16, 2014 11:25 pm ] |
| Post subject: | Re: trick anyone? |
measure and match wear marks or just watch the leftie for a while
| Author: | desmoluci [ Thu Jul 17, 2014 1:20 am ] |
Why put used, mismatched parts in your bike? Unless the parts are unavailable, I would hone it and put new rings on the pistons if they measure out correctly. All that hassle to build a pokey smoker.
| Author: | Brutus [ Sun Jul 20, 2014 9:00 pm ] |
You're right if this isn't possible. It's all about reducing costs if possible. Got more projects I'm working on ![]() Léon |
| Author: | Mc tool [ Mon Jul 21, 2014 12:54 am ] |
Brutus, I guess in a perfect world you would fit new rings and all that other " more money than brains" stuff, but I bet if you just pick a piston and rings , stick them in one of the cylinders , same for the other, assemble as usual and start er up , and you wont be able to pick the difference from new parts . 14k is just run in and it would be a waist to not use those parts somewhere. There are people out there that will wank on about only using new original parts, fitted in surgically clean workshops , and look down their ( large red ) noses at anything that's not factory or correct.................a lot of these Dicks hardly ride their bikes ... if at all, in the real world . Not something I have noticed here............um , if you have an RD400 you probly know what I mean
| Author: | desmoluci [ Mon Jul 21, 2014 12:16 pm ] |
| Author: | bmw851 [ Mon Jul 21, 2014 12:56 pm ] |
[quote="Mc tool"if you have an RD400 you probly know what I mean [/quote]Possible thread hijack which someone will delete if needed, but what the F@!#*, so how is the holey piston RD project coming along anyway? Cheers Himself
| Author: | Brutus [ Mon Jul 21, 2014 6:14 pm ] |
| Author: | Mc tool [ Tue Jul 22, 2014 6:03 am ] |
| Author: | desmoluci [ Tue Jul 22, 2014 11:06 am ] |
| Author: | Mc tool [ Wed Jul 23, 2014 4:38 am ] |
| Author: | bmw851 [ Wed Jul 23, 2014 10:24 pm ] |
| Author: | ducapaso [ Sun Jul 27, 2014 6:12 pm ] |
By the way, I can see some kind of "MP" logo impressed in my vertical cilinder, close to the belt cover. Is it standard or do I have big bore too? |
| Author: | Brutus [ Wed Jul 30, 2014 7:59 pm ] |
| Author: | paso750 [ Thu Jul 31, 2014 7:41 am ] |
