ducatipaso.org • View topic - Torque setting for clutch plate screws?
It is currently Tue Oct 27, 2026 12:32 pm
 Post subject: Torque setting for clutch plate screws?
PostPosted: Fri Jul 11, 2014 4:14 am
Putting my clutch back together (finally), and I don't see a torque setting for 6 screws that hold the pressure plate against the basket. Do you just snug the plate up to the posts, hand tight?
Thanks!
1988 Paso 750 #753965
1997 Monster 750
 Post subject: Re: Torque setting for clutch plate screws?
PostPosted: Fri Jul 11, 2014 9:01 am
last point of the torque overview in the workshop manual:
Clutch control disc fast. screws: 7,8-9,8Nm (5,8-7,2 lb/ft)
Btw if you can`t find one value its worthwile checking the 906, Sport or 907ie manual.
PostPosted: Fri Jul 11, 2014 11:10 pm
1997 Monster 750
PostPosted: Tue Jul 15, 2014 2:58 pm
Hope I caught you in time - I don't know which bike you have, but you hinted at the best approach as these screws are a candidate for overtightening and the threads on the 6 posts are often close to being stripped. Using a torque wrench at such low figures is questionable even if it's a high quality one as it's still possible to overtighten the fixings. It's much better to 'feel' all 6 up by hand with both screw and tapped post totally dry of all lubricant if possible. It's impossible to convey accurately but as an approximate guide you should just be able to turn the engine over (plugs out) when tightening.
PostPosted: Tue Jul 15, 2014 8:30 pm
Yeah, I figured they wouldn't need to be honked on too much, since they each have a spring putting negative pressure against them through the plate, making the plate act a bit like a lock ring. (Also, I've got an '88 Paso 750)
Thanks!
1997 Monster 750
PostPosted: Wed Jul 16, 2014 9:20 am
Not much pressure at all. The spring posts snap off very easily.
