| paso panel compatibility question http://ducatipaso.org/forum/viewtopic.php?f=1&t=701 |
| Author: | 750pheonix [ Mon Oct 17, 2005 10:38 pm ] |
| Post subject: | paso panel compatibility question |
Are the air-vent covers the same on 750 and 906 models? I have to sort out a 750 fairing but it already have a 906 fairing (I bought it that way)... and also are the side panels the same shape and fixture points? it would be useful to know to save time and money putting the 750 back to how it is meant to be. thanks in advance |
| Author: | Skins [ Mon Oct 17, 2005 11:50 pm ] |
| Post subject: | |
If it's any help (you may be able to compare 906 part numbers through a dealer, or some one else with a parts book) these are the part numbers for the Paso 740 panels: air conveyors (air vent covers) right 037099730, left 037099720 side panels (below the seat) right 037099890, left 037099880 half fairings (hanging off the tank) right 037099770, left 037099773 Good luck! |
| Author: | ducster [ Tue Oct 18, 2005 4:29 am ] |
| Post subject: | |
:thumbdown: Fairings of 750 / 906 aren't the same. 750 upper fairing (windshield) has mountings quite more to the side panels. 906/907ie mountings are placed more at "Top Position". So the Side panels of 750 are quite a bit shorter. Under-Seat fairings may be the same for all Paso series. Fitting a whole 750 Fairing to a 906 or vice versa may work. Just measure the space between mounting holes at the fueltank. You can get 906/907ie-fairings at http://www.airtech-streamlining.com/euroz/prodduc.htm , completely or in parts. Greets, ducster |
| Author: | 750pheonix [ Tue Oct 18, 2005 3:30 pm ] |
| Post subject: | |
