ducatipaso.org :: View topic - threaded holes in my new headers?
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=1&t=7054
Author:  Pablo The Squirrel [ Mon Mar 02, 2015 9:38 pm ]
Post subject:  threaded holes in my new headers?
So, I bought these new headers on the internet. they have these threaded holes in them (pictured above) which my original did not have.
My original had a hole in it, that's why I needed a new one :) but not threaded....
Any ideas?
Author:  paso750 [ Mon Mar 02, 2015 10:26 pm ]
Post subject:  Re: threaded holes in my new headers?
some headers had connections for a gas analyzer.
The thread should be a R1/8 (conical).
The old plugs were #000047113 (now 78010091A). Not sure if #78010071A is the same.
Author:  paso750 [ Tue Mar 03, 2015 5:32 pm ]
my header
Author:  Pablo The Squirrel [ Fri Mar 13, 2015 7:46 pm ]
thanks. conical thread huh... the things you learn...
Author:  Pablo The Squirrel [ Wed Mar 18, 2015 1:34 am ]
and thanks for the part number. The local dealer had them in stock. :D
Author:  paso750 [ Wed Mar 18, 2015 9:35 am ]
got the washers, too? Applying some anti-seize is recommended.
Author:  Pablo The Squirrel [ Sat Mar 28, 2015 10:11 am ]
Author:  paso750 [ Sat Mar 28, 2015 10:48 am ]
use a copper washer
Author:  Pablo The Squirrel [ Sat Apr 11, 2015 9:43 pm ]
Author:  paso750 [ Thu Apr 16, 2015 10:09 am ]
that should be ok, too. It should just be a washer that also can seal.
Author:  higgy [ Thu Apr 16, 2015 10:01 pm ]
aluminum will work and are readily available
Author:  Pablo The Squirrel [ Mon Apr 27, 2015 2:44 am ]
Author:  paso750 [ Mon Apr 27, 2015 9:22 am ]
you want that bolt to sit airtight so you use a washer made out of a softer material than steel
Author:  Pablo The Squirrel [ Mon Apr 27, 2015 11:26 am ]
Page 1 of 1 All times are UTC
http://www.phpbb.com/
