ducatipaso.org • View topic - Back on the road
It is currently Fri Feb 27, 2026 12:20 pm
 Post subject: Back on the road
PostPosted: Sat May 09, 2015 6:48 am
Finally after some years on storage due to lack of tires (in italy we cannot legally use different tires or rim sizes), my 1987 Paso s/n 276 is back on the road fully functional now with Goldentyre "shoes" (the picture of course is before the visit to the the tire shop)
 Post subject: Re: Back on the road
PostPosted: Sun May 10, 2015 8:30 am
Real nice paso. Looks great. Did it run 100k km's?
Exhaust looks great. Any other modifications.
Léon
PostPosted: Sun May 10, 2015 9:11 am
nice bike. The interesting thing about the exhaust is that I have the identical one with a aluminium cover and it`s from L&W. It seems that it was also sold as BOS just like some other exhaust systems that exist under different brand names.
PostPosted: Sun May 10, 2015 9:31 am
The exaust are alluminium really, but they had some scratches and i put a carbon-like adesive sheet on it specifically made for high temp.
Other modifications, well basically it's all original. But i removed the air filter and put a fiat 127 abarth one (you can see it on the gallery at s/n 276). I did not touch the weber setting since and in case you need, you don t need to remove all the fairings.
And, yes The bike has nearly 100.000 km
PostPosted: Sun May 10, 2015 10:06 am
is that a NonFango rack and if so how is it installed on the rear? Do you have a picture with the rear side fairing off?
100.000km is hard to believe considering the condition :thumbup:
PostPosted: Sun May 10, 2015 11:04 am
The Rack is a GiVi and it has only two bolts each side. I have nonfango for the side bags but i don t keep it mounted when not needed.
this is the simple modification to the air filter:
PostPosted: Sun May 10, 2015 2:00 pm
That's a beautiful 87, I've always liked the chrome and silver accents a little better than the 88 black ones. Regards Arch.
PostPosted: Thu May 14, 2015 8:53 pm
Your bike is still in a very good shape! :)
PostPosted: Tue May 19, 2015 5:23 am
Of course! We need to meet for another chianti tour!
PostPosted: Fri May 22, 2015 4:21 pm
I'm still wondering about that airfilter. It seems so small.
PostPosted: Fri May 22, 2015 5:06 pm
It works great. I just added the black plastic spacer from a 906 weber, a plastic "roof" to avoid water ingestion in case of heavy rain And connected the two sides at the bottim of carburetor with an alluminium hose. To register the air screws, now you don t need to remove any fairing
PostPosted: Fri May 22, 2015 10:57 pm
