ducatipaso.org • View topic - Steering head bearings
It is currently Tue Oct 27, 2026 3:42 pm
 Post subject: Steering head bearings
PostPosted: Wed May 27, 2015 5:32 pm
I haven't dug into it yet, but I can tell I'm due for new steering head bearings. Just testing the waters before I start pulling things apart ... any gotchas I should keep in mind?
1988 Paso 750 #753965
1997 Monster 750
 Post subject: Re: Steering head bearings
PostPosted: Wed May 27, 2015 6:15 pm
The only tricky part is removing the inner race of the bottom steering bearing from the steering stem.
PostPosted: Wed May 27, 2015 6:19 pm
for everyone who has never done it
https://www.youtube.com/watch?v=_Ozfh93CvBs
https://www.youtube.com/watch?v=c-kVkqXiLdY
PostPosted: Thu May 28, 2015 6:48 pm
Certainly get tapered roller bearings instead of ball bearings. Last longer, feel better. Of course, good grease is important too. Plenty of it. Pretty hard to over grease a low motion bearing like the headset. Set it up with just tad of preload.
PostPosted: Thu May 28, 2015 10:20 pm
Unless you have some pretty trick bearing removing tools that lower inner bearing race is probly best ground ( dremel ) nearly right thru in 2 spots and then split with a cold chisel :)
PostPosted: Fri May 29, 2015 12:01 pm
PostPosted: Mon Jun 08, 2015 9:43 am
I normally cut an x pattern with a small angle grinder (a partly worn blade makes it easier as the diameter is smaller, but still be careful) and then knock out the triangular shaped bit with a cold chisel.
To get the lower bearing cup out of the headstock, I normally run a bead of weld around the cup surface after cleaning the grease off. When the weld cools it shrinks the cup and makes knocking it out very easy. A clean up with emery paper and a smear of copper grease makes getting it out the next time easier.
907IE
Paso 750
CB 900FD
KX 500
KTM 500 with Zabel 700 Engine
zx10
Mobylette Cady
