ducatipaso.org • View topic - Parts for Paso in US
It is currently Wed Apr 29, 2026 3:10 am
 Post subject: Parts for Paso in US
PostPosted: Wed Sep 23, 2015 2:24 pm
Hello people,
I have 2 questions.
Is there a good replacement voltage regulator I can find in the US? Or should I just go to the dealer for that ($$$)? I have searched the threads but there is nothing current (Ha!) on the subject that I see.
Next, for engine parts, like belts and whatnot, is the dealer still the best source? I don't mind supporting the dealer but if they just can't get the stuff where else should I look?
Thanks, Hunter
Just smile and nod..........
 Post subject: Re: Parts for Paso in US
PostPosted: Wed Sep 23, 2015 6:46 pm
Try this:
http://www.ebay.com/itm/NEW-VOLTAGE-REG ... f3&vxp=mtr
You can call them toll free and ask 'em all about it.
Or: http://www.bevelheaven.com
https://store.bevelheaven.com/Electrics ... -Cylinder/
Best of luck!
PostPosted: Wed Sep 23, 2015 9:50 pm
either the FH020AA, or SH775 R/R with connector kit.
PVC flexible wire sheathing. For the do it yourself wiring hookups. 18" of PVC sheathing comes standard. If your stock harness is good and you trust it this will
do the job for a partial Mosfet or SH775 upgrade.
Do it once and do it right.
Dielectric grease available below!!
$113.95 plus $6.50 S&H
everything else is junk by comparison :beer: :thumbup:
PostPosted: Thu Sep 24, 2015 2:40 am
Thanks! Getting it charging and some new belts is the last hurdle. I have been riding it around a bit on the battery, it's as much fun as I remember!
Hunter
PostPosted: Thu Sep 24, 2015 11:13 am
then there`s also
https://ca-cycleworks.com/ca-cycleworks ... belts/tbf1
https://www.electrosport.com/street-bik ... rectifiers
PostPosted: Thu Sep 24, 2015 12:41 pm
Ricks also has Mosfet regulators now and can rebuild your stator if needed or upgrade it
I would recommend you check your stator and wiring before replacing the regulator :thumbup:
PostPosted: Thu Sep 24, 2015 2:27 pm
