ducatipaso.org • View topic - adjustable idle jet..?
It is currently Fri Feb 27, 2026 6:34 am
 Post subject: adjustable idle jet..?
PostPosted: Sat Nov 28, 2015 6:10 pm
Anyone tried one of these..?
 Post subject: Re: adjustable idle jet..?
PostPosted: Sat Nov 28, 2015 6:23 pm
Couldn't resist.. Just ordered two :mrgreen: :mrgreen: . Guess I will need the stock o-ring to prevent leaking. Will keep you informed. Maybe no more hassel for tuning..? Might even be adjustable without taking the fairing off.
Léon
PostPosted: Tue Dec 01, 2015 9:35 pm
Nice, but... Not easy to set up!
PostPosted: Tue Dec 01, 2015 11:27 pm
now if some one could figure a way to add a power valve in a simple fashion
PostPosted: Fri Dec 18, 2015 8:14 pm
Have been busy with work, so haven't done much on the paso lately. Here a couple of pictures of the adjustable idles I received. Seems stock mid eighties of a Fiat. Nice quality with an rubber gasket fitted inside. Due to this rubber it takes some force to turn the needle. I recon this will keep the needles at the right setting:
