| I got a regulator but...... http://ducatipaso.org/forum/viewtopic.php?f=1&t=7273 |
| Author: | Hunter [ Tue Sep 29, 2015 5:25 pm ] |
| Post subject: | I got a regulator but...... |
..I need to be sure how to wire it so the smoke stays in! I have searched the board but I have not found a definitive answer on what to connect where. I have a 5 wire replacement for the 6 wire stock RR. Battery, ground and lamp are no problem but what do I do with the 2 yellows and 1 red of the alternator to connect them to the 2 yellows of the new RR? Please be gentle, I just don't want to torch anything! Thanks, Hunter |
| Author: | higgy [ Tue Sep 29, 2015 5:48 pm ] |
| Post subject: | Re: I got a regulator but...... |
| Author: | Hunter [ Wed Sep 30, 2015 12:41 am ] |
Thank you Higgy. One more question: On the original it seems that the red wire to the alternator had 12v on it from the regulator. Do I need to make a 12v connection to that wire externally for this to work now? Hunter |
| Author: | higgy [ Wed Sep 30, 2015 11:34 am ] |
NOTE: For models with 2 x Yellow and 1 x Red generator wires, please use type RR51, with both yellow generator wires connected together as 1 phase wire to the RR51, and the red generator wire as the second phase wire to the RR51. |
| Author: | Hunter [ Thu Oct 01, 2015 12:59 am ] |
So here's what I have: When I hook the 2 yellow from the alt together to one yellow of the RR and the red from the alt to the other yellow I get no charge. When I hook the 2 yellow from the alt to the 2 yellow on the RR I do get a charge and about 50 VAC on the yellows at 3k rpm. But will it live in the long run with the red to the alt disconnected? Hunter |
| Author: | higgy [ Thu Oct 01, 2015 10:58 am ] |
what regulator are you using ? make and model |
| Author: | Hunter [ Thu Oct 01, 2015 3:55 pm ] |
Higgy, It is this one: http://www.ebay.com/itm/261367017203?_t ... EBIDX%3AIT The instructions you listed are identical to those supplied with mine. When I hook it up as a 2 wire it works, as a 3 wire it does not. This is where Mr Spock raises his eyebrow and says "Fascinating". Any ideas? I suppose to be safe I should pull the engine cover off and have a look. I just put all the fairing back on!! Hunter |
| Author: | higgy [ Thu Oct 01, 2015 4:14 pm ] |
looks like the two yellow should be to the stator,should not matter which goes to which and the red should go to the battery unless of course you have the 3 wire stator
| Author: | Hunter [ Thu Oct 01, 2015 5:37 pm ] |
| Author: | higgy [ Thu Oct 01, 2015 6:57 pm ] |
