| Spark plug recommendations for 750 Paso http://ducatipaso.org/forum/viewtopic.php?f=1&t=7304 |
| Author: | Kurt woolley [ Mon Oct 26, 2015 8:12 pm ] |
| Post subject: | Spark plug recommendations for 750 Paso |
Can anyone give some help in choosing the right spark plugs for my 750Paso. Thank you. |
| Author: | paso750 [ Mon Oct 26, 2015 8:49 pm ] |
| Post subject: | Re: Spark plug recommendations for 750 Paso |
Champion RA6HC |
| Author: | Kurt woolley [ Tue Oct 27, 2015 12:15 am ] |
Thanks, I know that is what the owners manual says, But I have never had good luck with Champion Plugs. Have they worked well for you? Is there another better plug? I see the Bosch silver sport #7701 or Xr4cs listed. Would that be a better choice? Thanks for your help. |
| Author: | higgy [ Tue Oct 27, 2015 12:56 am ] |
+1 Champion RA6HC |
| Author: | Derek [ Tue Oct 27, 2015 9:24 am ] |
I've always has good results with NGK plugs. The DCPR8E is recommended for the 750 Paso. |
| Author: | Brutus [ Tue Oct 27, 2015 10:52 am ] |
| Author: | paso750 [ Tue Oct 27, 2015 6:13 pm ] |
while you can go with iridium, platinum whatever plugs you`ll notice that the most simple ones work best. |
| Author: | Kurt woolley [ Thu Oct 29, 2015 2:42 am ] |
Thanks for the help, one & all! |
| Author: | ducinthebay [ Thu Oct 29, 2015 4:50 am ] |
The champions run best in the Sport for me. And they are cheap. Less than $2 at the local auto parts store. I never had a good view of Champion plugs in the past, but they work better than any $10 plug I've tried. Cheers, Phil |
| Author: | Kurt woolley [ Thu Oct 29, 2015 4:51 am ] |
Thanks again! |
| Author: | Kurt woolley [ Thu Oct 29, 2015 4:53 am ] |
Just bought them at Autozone for $1.95 each! I hope they work... |
| Author: | higgy [ Sat Oct 31, 2015 2:13 am ] |
if you would do a little searching here on plugs you would find a lot of Paso owners before they had a Paso wouldn't put champions in there worst enemies lawn mower.Then they bought a Paso,or 2 or 3 and we all use Champions now NGK iridiums work but the simple fact is champions will last longer and for a lot cheaper |
| Author: | Kurt woolley [ Sat Oct 31, 2015 5:18 am ] |
Thanks for all the info! Such a Cheap little plug on such a Great motorcycle. I am glad that they work! |
