ducatipaso.org • View topic - stock rear shock
It is currently Mon Mar 02, 2026 3:15 am
 Post subject: stock rear shock
PostPosted: Mon Nov 07, 2005 2:37 am
PostPosted: Tue Nov 08, 2005 8:08 pm
If U have Öhlins, ITS that, but i dont know that older Marzhocci in 750. Btw, that Öhlins is much better shock :thumbup:
That 907 later model rear Marzhocci is, cause mine was rebuild by Öhlins maintainer. Also i find rebuild kit from Ducati, but i am not sure, is it anymore available.
Paso 750
Paso 907IE
 Post subject: rear shock
PostPosted: Fri Nov 11, 2005 10:09 pm
My Paso has the stock Marzocchi shock. I'd like to get a used Ohlins for it. What part/model number Ohlins will fit a 750 Paso? I'm also going to call the dealer Monday and find out if there is a rebuild kit for the Marzocchi.
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
 Post subject: Re: stock rear shock
PostPosted: Sun Nov 13, 2005 10:16 am
PostPosted: Sun Nov 13, 2005 10:29 am
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
PostPosted: Sun Nov 20, 2005 3:00 am
I have the same seeping issue with my 88 Paso shock. Works Performance produces a shock for the Paso. The remote reservoir installs with hose clamps, so it's not the cleanest install. My shock continues to work pretty well despite a drip here/there, so I haven't installed the WP unit yet. I plan to weld up an aluminum clamp of some sort, that will make the shock worthy of being installed on my Paso. Hose clamps!
PostPosted: Sun Nov 20, 2005 8:19 pm
The Works Performance shock is only $350 as well. If you do get one let me know how it feels. I've also had a few crazy thoughts of just getting an Ohlins, but have been so far unable to find any info as to which model would fit the Paso.
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
PostPosted: Wed Nov 23, 2005 6:23 pm
Hi !
Original Paso 750 Öhlins is modell: CA 508, but i am 98% sure, that You cant find such new from any Öhlins shop anymore.
Paso 750 -89
Paso 907IE -91
ST4S -02 (tomorrow i got it from Germany) :lick: (cant wait!!!!)
