ducatipaso.org :: View topic - Doing the 900ss CV carb swap
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=1&t=7429
Author:  viper1 [ Wed May 11, 2016 11:25 am ]
Post subject:  Doing the 900ss CV carb swap
I decided to pick up a set of 94 900ss carbs to toss on the 750. I'm sick of dealing with the Weber issues! Whats all needed to make the switch? The carb manifolds & rubber gaskets. I'll end up getting separate filters....anything else I need to get or should know?
Author:  paso750 [ Wed May 11, 2016 2:13 pm ]
Post subject:  Re: Doing the 900ss CV carb swap
check the Technical FAQs
Author:  viper1 [ Thu May 12, 2016 1:25 am ]
Author:  paso750 [ Thu May 12, 2016 6:58 am ]
Author:  viper1 [ Thu May 12, 2016 11:09 am ]
Author:  Rickman [ Thu Sep 20, 2018 1:47 pm ]
I just did mine, and I am using a small vacuum fuel pump, (3psi), with a return line that t's off just before the carbs. All the info was on the forum.
41801964_2074149295931197_353833755330215936_n.jpg331.jpg [ 76.89 KiB | Viewed 8673 times ]
Author:  Rickman [ Mon Sep 24, 2018 2:44 pm ]
I'm setting mine up this week, once the carbs are on, you'll need a small vacuum fuel pump, i replaced the screw in my intake manifold with an M5 x 6mm brass fitting, my fuel line comes out of the tank and goes to a fuel filter, then the vacuum fuel pump then to a t or y, one line will go to the carb and the other is a return back to the tank. They also recommend a small bottle for the two vent tubes and the float bowl overflow line also. Once mine is set up, I'll add some pics if you'd like.
-Rickman
Page 1 of 1 All times are UTC
http://www.phpbb.com/
