| Running problem. http://ducatipaso.org/forum/viewtopic.php?f=1&t=7441 |
| Author: | desmoluci [ Thu May 26, 2016 2:57 am ] |
| Post subject: | Running problem. |
Ran the bike through the gears pretty hard today, and when I backed off it started running on one cylinder. When you open the throttle more, it starts running on two again with an occasional backfire through the exhaust. Changed plugs and no change. Anyone have any ideas what the problem may be? |
| Author: | Derek [ Thu May 26, 2016 8:26 am ] |
| Post subject: | Re: Running problem. |
Blocked idle jet? |
| Author: | paso750 [ Fri May 27, 2016 8:23 am ] |
do check the voltage at the coils and CDI units and the wiring mod in the FAQs. |
| Author: | Brutus [ Fri May 27, 2016 1:08 pm ] |
I was thinking of the coils also. Be sure to check corrosion on the pins where its connected to the wiring loom. Had a simular issue couple of years ago. Some sandpaper on the connection pins and it was running on both cylinders again. Léon |
| Author: | desmoluci [ Thu Jun 09, 2016 5:31 am ] |
Thank you, I'll start with the coils then to the carb. Sorry for the late reply, haven't been online for awhile. |
| Author: | ducinthebay [ Sun Jun 12, 2016 1:57 pm ] |
I agree with the plugged jets theory. Phil |
| Author: | Mc tool [ Sun Jun 12, 2016 10:03 pm ] |
