ducatipaso.org • View topic - Metallic shavings on oil plug
It is currently Mon Oct 26, 2026 2:43 am
 Post subject: Metallic shavings on oil plug
PostPosted: Mon Oct 03, 2016 6:49 am
Hello Gents!
Would like to say hello to everyone, as this is my first post :)
I've been looking for an answer on the forum, but seems that my searching abilities are wack.
Hence the question:
Recently I've bought a 1990 750P Paso with 27k km's on the clock. While changing the engine oil, I've encountered metal shavings on the oil plug (see attached link for photo: https://drive.google.com/open?id=0B0PZn ... 0hmeGt3elk)
From my initial investigation it seems that this could be the gearbox "shaving" off?
What do you guys think?
Cheers!
 Post subject: Re: Metallic shavings on oil plug
PostPosted: Mon Oct 03, 2016 7:47 am
could also be a loose crankshaft plug but I`m not sure if the plug is aluminium in which case you`d find particles on the mesh filter not on the magnet.
PostPosted: Mon Oct 03, 2016 8:19 am
True! Thanks for the remark. I am also not aware whether this model had alu gallery plugs...
I checked the mesh filter and it was totally clean.
Ps. Love your 'Joe Bar Team' avatar! :)
PostPosted: Mon Oct 03, 2016 9:55 am
Love your leather saddle avatar :rimshot:
PostPosted: Wed Oct 05, 2016 12:24 pm
Crank plug metal looks more like nail clippings. And in aluminum.
Are the metal on plug magnetic?
PostPosted: Wed Oct 05, 2016 5:31 pm
Yes, magnetic. Approx. 2-4mm long 'strips/particles' of metal...
PostPosted: Thu Oct 06, 2016 8:22 am
It looks like shards of gear material but there is an awful lot of it. How has the sprag clutch for the starter been behaving? A friend had the sprag on his Monster fail and it produced a lot of similar metallic particles.
PostPosted: Thu Oct 06, 2016 8:33 pm
Good point with the sprag clutch! Although, I believe it is running good at this point, no sounds that would indicate a malfunction (I checked it with a stethoscope :) )
I'm attaching also a video of the engine starting/running -> https://drive.google.com/open?id=0B0PZn ... k5Ma0pEU0U
