| Leaking Clutch Fluid ??? http://ducatipaso.org/forum/viewtopic.php?f=1&t=752 |
| Author: | naster [ Sun Nov 13, 2005 5:54 pm ] |
| Post subject: | Leaking Clutch Fluid ??? |
| Author: | BikerBard [ Mon Nov 14, 2005 1:03 am ] |
| Post subject: | |
| Author: | jcslocum [ Mon Nov 14, 2005 12:33 pm ] |
| Post subject: | |
| Author: | Rodney [ Mon Nov 21, 2005 5:34 am ] |
| Post subject: | |
also check the pressure plate as you may still have the three little ball bearings and cup that the slave presses up against . ducati dont make them anymore they have a different pressure plate with no moving parts on them as the slave has a rotating centre which the pressure plate runs against check that this has not siezed. you may have to replace it as well as the pressure plate. i had do do both and the clutch plates just after i purchased my bike be careful with the clutch basket bolts they can strip very easily. good luck Rodney |
