ducatipaso.org • View topic - 750 Weber woes - same same but different?
It is currently Wed Feb 25, 2026 2:04 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: 750 Weber woes - same same but different?
PostPosted: Fri Apr 14, 2017 5:55 am
Hi All,
I picked up a yellow 87 a couple years ago and got it going after some neglect from the PO. I haven't ridden it much (I have a bit of a stable that I cycle through) but would like to move this guy to the front of the herd.
Running a 44 DCNF carb (jet info below) with stock exhaust and intake with K&N air filter.
I've tried to do my due diligence and search for every issue possible on the site, but here's a rundown of what's happening.
-Starts up okay (except after sitting for a while).
-Inconsistent idle, even when screw is in to make it idle a little too high - after a throttle blip, it stumbles and dies. "inconsistent" meaning sometimes it just chugs along at idle, but most of the time it tails off and dies. I'm uploading a video now.
-Float is right at 46mm, double checked.
-Pulled jets, cleaned carb - everything is squeaky
-There's a bit of fuel under each gasket (trumpets and float bowl/top). Leak?
When riding, it bogs mid-full throttle and dies without a little throttle at stop lights.
I pulled the float again today to check, still at 46. Reading up on jets and the info varies all over the place. I can't find a definitive where's what for jets and mixture screws on this carb. I figured some jet experimentation is due, but I can't find a good source for jets (I usually go to jetsrus.com, but they have nada for Webers). UNLESS I'm looking at the wrong things that I'm calling jets. The sizes I have don't jive with what I can find - what I thought was the jet looks more like an emulsion tube. See pic below.
Questions:
Is there a diagram with the right labels, so I know what I'm referring to?
Am I reading the wrong sizes? The only jet I can find is in sizes 20-50 or so - mine says 145 on the tube and 170 F44 on the jet. What I thought was the Etube says 110 F7.
I expect a certain amount of PITA from my Italians, but these fairings are getting to be too much to take on and off for tweaking, hoping to just get this big banana going. Thanks in advance.
by , on Flickr
 Post subject: Re: 750 Weber woes - same same but different?
PostPosted: Fri Apr 14, 2017 6:30 am
Bike idling here: https://youtu.be/ceWlQeOCJXg
PostPosted: Fri Apr 14, 2017 6:51 am
the top thing with the thread is an air corrector jet , main jets are in bottom of float bowl . And the paso will run like a bag of hairy arseholes with out the air cleaner/box ( inc cover ) fitted , so before I get to worried put it all back together and try it , you can still get at any adjusting screws with the air box fitted :)
PostPosted: Fri Apr 14, 2017 7:00 am
PostPosted: Fri Apr 14, 2017 8:59 am
PostPosted: Fri Apr 14, 2017 9:20 am
PostPosted: Fri Apr 14, 2017 1:14 pm
PostPosted: Fri Apr 14, 2017 3:00 pm
fuel at the gasket surface would indicate something is warped.
I would suggest a brand new gasket with some anaerobic sealer applied to both sides
You could also try to straighten the carb top which would require a press and a lot of careful application of force opposing the bend. Small steps so you do not break the top. Application of heat in an oven at 350 would help. Be sure to wash the top with plain old soap and water before putting in the oven. It must not even have a hint of fuel smell. Remove the entire float assembly and all associated pieces. Only the stripped top goes in the oven. Any extra pieces left installed will cause more issues down the road.
Just watched your video, You are running on one cylinder,could be the carb but as G suggested go over your complete ignition circuit,primary and secondary :thumbup:
PostPosted: Fri Apr 14, 2017 9:29 pm
PostPosted: Fri Apr 14, 2017 9:57 pm
PostPosted: Fri Apr 14, 2017 10:51 pm
Is there a return fuel line back to the tank from the carb , or a pressure regulator . The fuel pump can overpower the float valve ,and as you describe leaking and black plugs .... sounds rich . My paso has Tee in the fuel line just before it enters the carb and just goes back to the tank return , some run a diaphragm pump off the Monster and some have a fuel pressure reg .
As Higgy and paso750 have said the electrics can ( and often do ) play up , nothing hi tech just switches and connectors that wernt great in the 1st place and are now suffering a bit of age as well , easily fixed/ improved .... heaps of posts on that . Adding a main relay goes a long way to sorting it.
PostPosted: Fri Apr 14, 2017 11:02 pm
Just ordered a fuel regulator - there is a T before the carb. I have it draining into an aux tank while on the bench.
PostPosted: Sat Apr 15, 2017 1:51 am
The Tee before the carb does work ok as long as the return line is not to restrictive..... and its worked till now . Don't get me wrong regs are good but the T is cheaper :)
PostPosted: Sat Apr 15, 2017 6:10 am
PostPosted: Sat Apr 15, 2017 9:08 am
I`d also replace the NGK spark plugs for Champion RA6HC. For some reason most Pasos run a lot better with them.
What you will possibly find when measuring the voltage at the coils is that instead of 12V at idle there will be only 9-10V. With that voltage the coils can barely do their job and sometimes one won`t create a spark at all.
