| Fork difference between 750 and 906 and 907ie http://ducatipaso.org/forum/viewtopic.php?f=1&t=7976 |
| Author: | nojapan [ Wed Sep 19, 2018 12:50 pm ] |
| Post subject: | Fork difference between 750 and 906 and 907ie |
Hello Everyone, does someone of you know the forks difference between 750 and 906 and 907ie ? Thanks |
| Author: | paso750 [ Wed Sep 19, 2018 1:27 pm ] |
| Post subject: | Re: Fork difference between 750 and 906 and 907ie |
as it says in the FAQs Stanchion tube lengths: Paso 750 left: 580 or 590mm right: 560mm Paso 906 left: 630mm right: 600mm The ones of the 907 are probably different as well. Fork spring length is also different. The fork legs of the 750/906 are for brake calipers with 108mm mounting hole distance. The ones of the 907IE are for 40mm. Also the caliper mounts for early 907IE were lower as 300mm discs were used and later 320mm. |
| Author: | nojapan [ Wed Sep 19, 2018 6:44 pm ] |
Thanks for the information! I will save it! |
| Author: | Tamburinifan [ Thu Sep 20, 2018 12:09 pm ] |
907 forks longer than 750/906, don`t know how much though. |
