| Rear disc brake http://ducatipaso.org/forum/viewtopic.php?f=1&t=8001 |
| Author: | nojapan [ Tue Oct 09, 2018 10:03 am ] |
| Post subject: | Rear disc brake |
Dear Enthusiast, I would need a rear brake for 750 wheels. Do I need to look for it only as Ducati Paso 750 or it is compatible with other motorcycles? Thanks for your help! Gab |
| Author: | Frank.61 [ Tue Oct 09, 2018 1:51 pm ] |
| Post subject: | Re: Rear disc brake |
Rear brake is the same as the 906 Paso and 750 sport (NOT the 907 !), but what do you need: disk, caliper, caliper mounting bracket .....? Assuming you have the master brake cylinder and will buy new brake pads and brake line?! The caliper, a Brembo P108, is relatively easy to find new or used (ebay etc.). The disk, new, is a bit more difficult but a good second hand does the job - though you have to clean it or even sometimes you have de-rust it, which isn't to difficult with some sandpaper) https://www.ebay.com/itm/Ducati-paso-75 ... 547?hash=i Same with the caliper mounting bracket: relatively easy to find sevond hand, a.o. ebay Let us know .... |
| Author: | nojapan [ Tue Oct 09, 2018 7:03 pm ] |
Sorry Frank, just the disc, for the rest I have all. Thanks for the link but to get the disc in Italy it will cost too much. I will look locally. Thanks. |
| Author: | Frank.61 [ Tue Oct 09, 2018 8:18 pm ] |
No problem, if you do not succeed try Rudy. |
| Author: | nojapan [ Thu Oct 11, 2018 8:19 am ] |
All goodmorning, as I did not find new discs at cheap price I decided to ask to a local producer to make it for me. I already asked to RS BIKES located in Italy several discs and for the Paso rear one he asked me 60 euro + shipping. I checked into the web and found the following measures: EXT diam 270mm INT diam 139mm CENTER HOLES at 154mm HOLES diam 6,5mm Is that correct? I want to be sure before to place the order. THANKS ! |
| Author: | paso750 [ Thu Oct 11, 2018 9:07 am ] |
The holes for the screws are 8,1mm as they are M8 bolts. The inner diameter of 139mm seems too big. I have an adapter for a Marvic rim and it's diameter is 136mm so the disc should be only slightly larger. |
| Author: | Frank.61 [ Thu Oct 11, 2018 9:26 pm ] |
Assume it is a stainless steel disk? To be honest, it's quit cheap especially for a one off ..... I paid for a stainless steel version 137 euro's. |
