| Help! Have NOS Paso tank that needs filler cap and flange Et http://ducatipaso.org/forum/viewtopic.php?f=1&t=8002 |
| Author: | Scuderia Alpha [ Tue Oct 09, 2018 3:39 pm ] |
| Post subject: | Help! Have NOS Paso tank that needs filler cap and flange Et |
Hi Folks, I have a 1988 Paso 750 which had a leaky tank, that was one pinhole too many...so I found a NOS tank in so.cal. mint inside, still had foil covers over the ports with red overspray, neat to find a relic like this. Anyway, my existing tanks gas cap, flange and fuel tap do not fit this tank!! The new tank has a bigger hole with a different screw count and the gas tap is a female 20mm hole on the opposite side from where my old one had a male threaded fitting!!??? What year and model Paso tank do I have? Paint looks right, cagiva elephant in Ducati logo (my old tank had no elephant...) Will attach some pics with measurements shortly... |
| Author: | Scuderia Alpha [ Tue Nov 06, 2018 6:56 pm ] |
| Post subject: | Re: Help! Have NOS Paso tank that needs filler cap and flang |
Looks like the tanks is from a 907 i.e. so now looking for the gas cap and flange+gasket for this thing, any help would be terrific! Thanks folks... Chris |
| Author: | higgy [ Tue Nov 06, 2018 11:54 pm ] |
you can most likely still find one at your local Ducati dealer. Same on used on the 851 If not try Ed Miltch at Guzzitech he recently took in a 907 |
| Author: | randtcastell [ Wed Nov 07, 2018 6:28 pm ] |
I have a new one in at my shop for a P750 tank purchased from https://www.ebay.com/str/valtermotousa/ I also have spare SS M6 countersunk allen head machine screws. Hit me up if Ed Milch can't do ya. Best of Luck! Pictures please! |
| Author: | paso750 [ Thu Nov 08, 2018 8:54 am ] |
That seller has an interesting NOS 'P750' tank. It's a 907IE tank with a P750 paintjob. It has the connections on the right and the brackets for the fuel pump and tubes. Since the P750 was out of production when the 907IE came out I wonder why Ducati did this.
| Author: | Scuderia Alpha [ Thu Nov 15, 2018 5:52 pm ] |
Hi Folks, Thanks for the assist...and sorry about my slow responses, work and home life a bit hectic... Best, Chris |
