ducatipaso.org
http://ducatipaso.org/forum/
Paso 750 fuel line run
http://ducatipaso.org/forum/viewtopic.php?f=1&t=8118
Author:  thefudginator [ Sun May 05, 2019 3:53 pm ]
Post subject:  Paso 750 fuel line run
Hi Folks. I stripped out the fuel lines on my Paso 750, and started replacing the fuel lines with new pipe. Only to find the fuel filter connections cracked. Took me a couple of weeks to getting the replacement by which time I had forgotten how they went together (yes I know I should have taken pictures). Anyone got a few pictures of the pipe connection arrangements and the location of the filter in place? Sorry for asking for daft information. I usually work better than this. any help appreciated. Cheers :banghead:
Author:  paso750 [ Sun May 05, 2019 5:21 pm ]
Post subject:  Re: Paso 750 fuel line run
Posting in the classifieds section won't help ;) so I moved your question.
The fuel line arrangement is simple.
From fuel petcock to filter to pump to Y piece. From there to the Weber and from the second connection back to the tank (rear connection)
Author:  thefudginator [ Mon May 06, 2019 10:42 am ]
Hi Paso750. Many thanks for the info. My fuel line also has a T piece in it. Also, I would like to know if the fuel filter runs on the inside of the fram or the outside? Please see attached pictures. One of a complete line set from a Paso I just stripped, the other showing the new lines I made up with the T piece. Any advice appreciated.
PS thanks for moving the question.
I seem to be struggling to add the pictures.
Author:  paso750 [ Mon May 06, 2019 11:25 am ]
The reason you can't upload pictures may be that they are too big.
Here two pictures taken from old magazine articles.
Author:  thefudginator [ Mon May 06, 2019 11:31 am ]
Hi 750 Paso. That is great. I can now see which location the filter runs. Any idea on the T?
Author:  paso750 [ Mon May 06, 2019 1:23 pm ]
The position of the T makes no sense to me.
There are 2 possible fuel line setups. The first one below is the one you have in your first picture. That is if your tank has a fuel return connection.
The second is if the tank has no fuel return connection. Then the fuel is sent into a loop instead to reduce pressure.
Note that in the Y-piece there's a Dell Orto jet as reduction piece. As in the pictures that should be in the exit to the tank/loop. Btw the fuel petcock shows forward not to the right side as shown in the drawings.
Author:  thefudginator [ Mon May 06, 2019 4:15 pm ]
That is really appreciated. Many thanks for solving this problem. My bike is a very early one, so the return pipe is probably the issue. Cheers 750Paso :beer:
Page 1 of 1 All times are UTC
http://www.phpbb.com/
