| Side stand switch http://ducatipaso.org/forum/viewtopic.php?f=1&t=8120 |
| Author: | AmcG [ Sun May 12, 2019 9:44 pm ] |
| Post subject: | Side stand switch |
Hi How do I remove it? It’s a single wire type. (I have removed the sidestand already) Thanks |
| Author: | Derek [ Mon May 13, 2019 8:14 am ] |
| Post subject: | Re: Side stand switch |
Unless it's different from the 907 switch, loosen the lock nut then it just unscrews. |
| Author: | AmcG [ Mon May 13, 2019 11:12 am ] |
Thanks... I’ve asked the question badly, I want to discard the switch. Do I earth the wire? I don’t want any form of cut out. The side stand is removed. Thanks Alistair |
| Author: | Derek [ Mon May 13, 2019 12:55 pm ] |
If you earth the wire the light in the dash will light up. If you don't want it lit leave the wire disconnected. |
| Author: | AmcG [ Mon May 13, 2019 4:45 pm ] |
Thanks! Will get by without the light. |
