It is currently Tue Oct 27, 2026 3:12 pm
[ 3 posts ] |
| Author |
fasterdammit
Post subject: 750 ignition wiring upgrade (attn. jcslocum) Posted: Tue May 21, 2019 11:59 pm |
| paso grand pooh-bah |
Joined: Wed Jan 19, 2005 12:00 am Posts: 708 Location: CNY, US
Hey Jonathan -
I'm going through the PDF to do the wiring upgrade for improved starting (the addition of 2 new 30a/12v relays) and I just realized an inconsistency:
In Step 5 , you clip then pull the 12ga brown wire from the main power feed plug under the tank, attach a female push-on connector and indicate it will be connected to terminal #30 on the relay.
Later, in step 7, you add the 30a inline fuse to the battery feed post on the starter solenoid with a ring terminal, and attach a female push-on connector to the other end - and that will mount to post #87 on the relay.
However - and here's the conundrum - in the diagram under step 9, you show the "Power feed from starter solenoid. 30 and fuse" going to the vertical post #30, and the "Brown wire cut from the harness that goes to the fuse panel" connected to horizontal post #87. Those are backwards from the written instruction.
So ... Which is the right one? Thanks in advance!
Jake
_________________ Just because you're not dead doesn't necessarily mean you're living, either.
1988 Paso 750 #753965
1997 Monster 750
| Top |
Post subject: Re: 750 ignition wiring upgrade (attn. jcslocum) Posted: Wed May 22, 2019 1:28 pm |
Jake,
it doesn't matter. It'll work both ways. Contact 30 and 87 of a relay are not directional. If you want to stick on what's printed on the relay 30 is the number for battery +.
| Top |
fasterdammit
Post subject: Re: 750 ignition wiring upgrade (attn. jcslocum) Posted: Wed May 22, 2019 4:01 pm |
1997 Monster 750
| Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 17 guests |
