ducatipaso.org :: View topic - Rear shock size
ducatipaso.org
http://ducatipaso.org/forum/
Rear shock size
http://ducatipaso.org/forum/viewtopic.php?f=1&t=8173
Author:  AmcG [ Thu Sep 05, 2019 11:45 am ]
Post subject:  Rear shock size
Hi
Can anyone confirm the dimensions for the rear shock?
Length eye to eye- 365mm
Eye holes -10mm
Across flats -22mm
Many thanks
Alistair
Author:  paso750 [ Fri Sep 06, 2019 5:24 pm ]
Post subject:  Re: Rear shock size
the dimensions
Author:  AmcG [ Fri Sep 06, 2019 5:33 pm ]
Hi
Once again, super helpful.
Alistair
Author:  Ronald [ Sun Sep 08, 2019 4:42 pm ]
Hi Alistair,
Maybe this is also interesting for you: the 'technical data sheet' of the Öhlins DU508 shock absorber which was installed on the first 950 or so 750 Paso's. The form is named 'Mounting instruction', but there are no instructions on it whatsoever :) Nevertheless, there are some sizes on it.
Author:  AmcG [ Sun Sep 08, 2019 4:56 pm ]
Ronald
Thank you! It confirms the length.
Alistair
Author:  paso750 [ Tue Sep 10, 2019 8:57 am ]
Author:  AmcG [ Sat Sep 14, 2019 10:42 pm ]
New shock...
Page 1 of 1 All times are UTC
http://www.phpbb.com/
