It is currently Sat May 18, 2024 1:20 am
[ 2 posts ] |
Author |
thefudginator
Post subject: Pase Engine Number - How old is this engine? Posted: Sat May 16, 2020 8:36 pm |
Joined: Fri Mar 11, 2016 9:16 am Posts: 9 Location: UK
Hi Folks. I just bough a tatty old Paso 750 1990, so one of the last. Log book says engine number is 754496, but the previous keeper said the engine had been replaced. Having had a look, it is stamped ZDM750LE750659. I guess that it is slightly older than the original engine? Does the LE mean anything? Many thanks.
_________________ Paso 750 Yellow in bits Paso 750 Red x 2 (one running) Paso 906 in bits. It is a habit I cant seem to give up!
Top |
angelix
Post subject: Re: Pase Engine Number - How old is this engine? Posted: Tue May 19, 2020 6:02 pm |
Joined: Thu Nov 29, 2007 2:38 am Posts: 338 Location: UK
I just checked the engine I have on my Special, it was from an Elefant 750 and the number is ZDM750LE*751354 , not far from yours.
my engine was coming form a very early bike, I wonder ... they look the same , the valve train is the same and should be a straight swap.
The primary on the elefant da 31-62, wilst on the Paso it is the same as the SS 36/71; The gearing is different too, unfortunately the only way to check that is either opening it or with a goniometer and a lot of patience
Top |
[ 2 posts ] |
Users browsing this forum: No registered users and 4 guests |
