| 750 paso ignition switch http://ducatipaso.org/forum/viewtopic.php?f=1&t=8342 |
| Author: | Fab [ Sat Oct 31, 2020 9:59 am ] |
| Post subject: | 750 paso ignition switch |
I have pulled the ignition switch off and found that the locking pin has snapped the housing Is there any other model ignition switch that will fit this bike |
| Author: | randtcastell [ Sat Oct 31, 2020 7:58 pm ] |
| Post subject: | Re: 750 paso ignition switch |
I am no specialist, but I assume you mean what I think you mean. If so then I do believe 750's and 900's '88-91 and may other models into the '90's all the same part number. Others will confirm or correct this. https://www.ebay.com/itm/Ducati-900ss-7 ... xyfyhRYYT0 You may find a nice used item fairly quickly. $40US seems like a fair price. Good Luck! :^) |
| Author: | Fab [ Sun Nov 01, 2020 4:26 am ] |
Thanks for the reply, no I’m after the ignition key switch barrel |
| Author: | Derek [ Sun Nov 01, 2020 11:32 am ] |
750, 906, 907 and 750/900 Supersport all have different part nos. but only the last 3 characters change so probably differing connectors/cable lengths. I be surprised if one from any of these models didn't physically fit but might need the wires adjusted. |
| Author: | Frank.61 [ Sun Nov 01, 2020 5:00 pm ] |
Hi, Also the height of the barrel is different .... Frank |
| Author: | Fab [ Sun Nov 01, 2020 10:08 pm ] |
Thanks for your help with this fellas, I will try to find one to fit this model |
