ducatipaso.org • View topic - 750 paso ignition switch
It is currently Wed Oct 28, 2026 2:15 am
 Post subject: 750 paso ignition switch
PostPosted: Sat Oct 31, 2020 9:59 am
I have pulled the ignition switch off and found that the locking pin has snapped the housing
Is there any other model ignition switch that will fit this bike
 Post subject: Re: 750 paso ignition switch
PostPosted: Sat Oct 31, 2020 7:58 pm
I am no specialist, but I assume you mean what I think you mean. If so then I do believe 750's and 900's '88-91 and may other models into the '90's all the same part number. Others will confirm or correct this.
https://www.ebay.com/itm/Ducati-900ss-7 ... xyfyhRYYT0
You may find a nice used item fairly quickly. $40US seems like a fair price. Good Luck! :^)
PostPosted: Sun Nov 01, 2020 4:26 am
Thanks for the reply, no I’m after the ignition key switch barrel
PostPosted: Sun Nov 01, 2020 11:32 am
750, 906, 907 and 750/900 Supersport all have different part nos. but only the last 3 characters change so probably differing connectors/cable lengths. I be surprised if one from any of these models didn't physically fit but might need the wires adjusted.
PostPosted: Sun Nov 01, 2020 5:00 pm
Also the height of the barrel is different ....
PostPosted: Sun Nov 01, 2020 10:08 pm
Thanks for your help with this fellas, I will try to find one to fit this model
