| Regulator/Rectifier replacement http://ducatipaso.org/forum/viewtopic.php?f=1&t=8343 |
| Author: | Alfaman [ Mon Nov 02, 2020 6:50 pm ] |
| Post subject: | Regulator/Rectifier replacement |
Hi All- I recently purchased a new regulator/rectifier from Electrosport (ESR515) to replace the OEM unit on my '88 Paso. I am theorizing that the dash light bulbs, tail light bulbs and the fuel pump have all burned because the bike was overcharging (roughly 16-16.5V). The problem is that while I thought the new unit would be plug and play- when I went to replace old with new, I discovered the connectors are different. The old unit uses molex type connectors whereas the new unit uses standard pin/pigtail connectors. There were no install instructions included with the new regulator and the color coding of the wires doesn't mach. I sent a note to electrosport and they weren't much help. Has anyone done this recently and if so, which wires correspond to which? Thanks for the help. |
| Author: | paso750 [ Tue Nov 03, 2020 8:33 am ] |
| Post subject: | Re: Regulator/Rectifier replacement |
Hi, have a look at the download topic on top of this forum. Also have a look at the 906 FAQs. G. |
