It is currently Sun Oct 25, 2026 2:58 am
Page 1 of 1
[ 3 posts ] |
| Author |
Message |
murphus
Post subject: 1988 Paso Valve Clearances Posted: Fri Mar 19, 2021 1:10 am |
Joined: Wed Jun 24, 2020 6:27 pm Posts: 50 Location: USA
I've searched the forum for a possible answer to this question, but maybe I'm using the wrong key words as I've come up empty. The question isn't what are the specified clearances, it's what, in the experience of those, well, more experienced, is too tight? Just checked the valves, and all of the opening shim clearances were what I'd call a very loose .003in, almost .004in, which is spec. I used the unload method for checking the closing shims and they're all in spec at .001in, with one being tight, perhaps on the order of .0008in. The shim caps all spin easily when I unload the closing rocker arm. Are my opening clearances acceptable against a recommended .004in? Is the one slightly tight closing clearance cause for concern?
This is my first Ducati, so my operating knowledge is limited. At present, I don't even know if the engine runs. I'm working through it slowly with the aim of ensuring it actually runs before I commit substantial time/money. OK, I know it'll take plenty of time, but ...
Thanks in advance for any insight.
_________________ 1973 BMW R75/5 1974 Laverda SF2 1976 Suzuki GT185 1983 Lavarda RGS 1000 1988 Ducati Paso 750 1995 BMW K75
| Top |
Derek
Post subject: Re: 1988 Paso Valve Clearances Posted: Fri Mar 19, 2021 10:35 am |
| paso grand pooh-bah |
Joined: Thu Nov 03, 2011 10:13 am Posts: 769 Location: Scotland
I'd be happy with those clearances. I'm not sure about the 750 engines but for the 904 at one time Ducati specified .003" inlet and .004" exh for openers, that was later changed to .004" and .005". Even if you can't measure the gap, as long as all the closers can spin when you press down on the closing rocker arm they are good
_________________ 1994 907ie 2017 Supersport 939 2015 Scrambler Classic 1982 Pantah 500SL (now sold)
| Top |
murphus
Post subject: Re: 1988 Paso Valve Clearances Posted: Fri Mar 19, 2021 8:12 pm |
Thanks for the input. Based on experience with other engines the numbers I got didn't seem far enough off to warrant a readjust, but not really knowing these engines or how tolerant they are I was interested in experienced opinions. From what I've learned, a previous owner sent the heads out to a shop in Chicago. This likely would have been in the mid- to late-90s. He apparently didn't feel confident attempting adjustment and didn't have access to shims, so he removed the heads and sent them out. I have no idea what shop, but assuming it was someone familiar with belt-drive Ducs.
| Top |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: No registered users and 8 guests |
