It is currently Sun Apr 28, 2024 8:27 pm
Author |
murphus
Post subject: Re: US Spec P750 Weber Recalibration Posted: Fri May 14, 2021 12:15 am |
Joined: Wed Jun 24, 2020 6:27 pm Posts: 50 Location: USA
Mike, mine is also 34mm. It'll be a bit before i get around to all of it, but I plan to copy your settings and see how it works. I have different emulsion tubes than you, F36 vs. F44. But as I need new emulsion tubes I'm leaning toward using the F44s that apparently work well on your bike. Will be interesting to see, and I'll certainly report back once I've set it up and run it.
_________________ 1973 BMW R75/5 1974 Laverda SF2 1976 Suzuki GT185 1983 Lavarda RGS 1000 1988 Ducati Paso 750 1995 BMW K75
Top |
Mike's bikes
Post subject: Re: US Spec P750 Weber Recalibration Posted: Fri May 14, 2021 9:12 pm |
Joined: Tue May 04, 2021 1:25 pm Posts: 10 Location: USA
My bike had a K&N filter element in the standard airbox when I got it. I changed that to an OE type paper element, making sure that it stayed in the sealing channel when the cover was clipped on. That change alone made a noticable difference. I mention it because the aftermarket cotton mesh elements seem ubiquitous.
Top |
Goldstar500
Post subject: Re: US Spec P750 Weber Recalibration Posted: Tue Jun 01, 2021 11:48 am |
Joined: Tue Jun 01, 2021 7:36 am Posts: 3 Location: Australia
I’m in the process of trying these settings on my Paso 750 Weber. I’ve just switched the 145 main jet to a 150. The rest of the settings are the same including the 34mm Venturi. I should be able to test it in a few days. It was already running well with no flat spots but I wanted to make sure it wasn’t too lean in the higher rpm.
_________________ 1988 750 Paso
Top |
Mike's bikes
Post subject: Re: US Spec P750 Weber Recalibration Posted: Tue Jun 01, 2021 6:52 pm |
Goldstar500, are you changing the auxiliary venturi from the original 3.5 to 4.5, or just the jets? Do you have a BSA Gold Star 500? Coincidentally, I have a 1961 500cc DBD Gold Star.
Top |
Goldstar500
Post subject: Re: US Spec P750 Weber Recalibration Posted: Tue Jun 08, 2021 10:29 am |
I haven’t touched the auxiliary venturis. I expect they are are standard though I haven’t checked.
I did the first proper test ride today on the new 150 main jets and it ran great. No hesitation when I opened the throttle fully from low revs in the higher gears. The Weber is so good on the Paso, that I don’t know why people go to the trouble of replacing it when it’s so easily tuned. As a side note, I did the coil ignition relay mod and engine no longer cuts out randomly at idle. You could easily blame the Weber for poor idling if you didn’t know about that mod.
Yes, I’ve got a 1939 M24. It runs great on post war ‘touring’ cams. The DBD would be a great bike too, though I’ve never ridden one. Nice to meet another BSA guy on a Ducati forum!
Top |
murphus
Post subject: Re: US Spec P750 Weber Recalibration Posted: Fri Jun 11, 2021 2:24 pm |
Well, my adventure into Weberdom just got a little interesting. Ordered up everything I need to rejet/reset, all arrived, oh boy, time to start work. Then discovered whomever last worked on the Weber screwed the fuel/air mixture screws in so friggin tight they actually started to blow out the inside of the throttle bore (see pics). Incredible. I've never seen anyone do that. Is there any chance it's useable like this? Asise from the likelyhood that I won't have shit for control over baseline fuel/air mixture, what will it mean to the rest of the operating range? More than a little bummed as I was excited about returning the Paso to stock. Anyone have a parts carb?
Attachments: |
Top |
Goldstar500
Post subject: Re: US Spec P750 Weber Recalibration Posted: Fri Jun 11, 2021 11:24 pm |
I believe the idle mixture screws are useful only for idle mixture setting. I read about this on a blog for the Weber DCNF from a Ferrari Dino owner. The idle jet itself is really the important one, since it controls from idle to 3000rpm. You might be able to get away with new idle mixture screws. Here is the DCNF blog: http://dino246blog.blogspot.com/2014/08 ... s-and.html
Top |
murphus
Post subject: Re: US Spec P750 Weber Recalibration Posted: Sat Jun 12, 2021 12:56 am |
Thanks for the link, useful information.
Top |
Post subject: Re: US Spec P750 Weber Recalibration Posted: Sat Jun 12, 2021 11:07 am |
paso grand pooh-bah |
Just a quick input Keep in mind automotive engines are quite different in their operating range and characteristics. Generally large bores and undersquare,water cooled and lower rpm ranges
Top |
a330us
Post subject: Re: US Spec P750 Weber Recalibration Posted: Fri Jun 18, 2021 3:36 am |
Joined: Mon Dec 02, 2013 2:31 pm Posts: 154 Location: winston salem, nc usa
Thanks for sharing those jets and changes to the original weber but since so many of us have aftermarket less restrictive mufflers on our bikes what changes to your jets and settings would you make? Thanks Arch.
Top |
Users browsing this forum: Google [Bot] and 6 guests |
