| Ignition pickups ? http://ducatipaso.org/forum/viewtopic.php?f=1&t=8393 |
| Author: | Stepaso [ Tue Jun 01, 2021 12:14 am ] |
| Post subject: | Ignition pickups ? |
My 1988 White Limited Paso #754059 started running on one cylinder the other day, on the way back from a 40klm ride to get an ice cream through classic North Auckland back country twisty bush clad roads with no-one else on them ... every time I stopped the motor would cool down and it would go again on 2 cylinders. limping home and after tracing no spark on the horizontal cylinder I found one of the pickups had gone open circuit, the other was 95ohm. The bike is ex America so has Kokusan Densi ignition electrics, After lots of research I find I can get a new set for about $500 NZ$ but there is discussion on this board where people have used the pickup from a Fiat Uno, the only other info is they cost $19. Can anyone offer any leads to reasonably priced parts or the part number of the Fiat Uno pickup ? Ducati OE# 260.1.001.1A 26010011A Regards Stephen 1988 Paso 750 White Ltd 1982 S2 |
| Author: | angelix [ Thu Jun 10, 2021 9:55 am ] |
| Post subject: | Re: Ignition pickups ? |
IGnitech in Czech republic sells an alternative replacement , however in NZ there is LIAM VENTER at Fast Bike GEAR (NZ!!) he has the replacement in stock for 49NZ$... http://www.fastbikegear.co.nz/index.php ... ts_id=6792 he is also developer and importer for IGNITECH, he might be able to help you with a full set up with hall sensors instead of the traditional pickups. He has a kit for the 900 , but i think the same can or could be adapted to the 750, really worth giving him a call. your pickups... would just be the pickups wiring going bad, it tends to crack so it could be something simple to fix, but I would go all the way and either replace them with new ones available through IGNITECH or FASTBIKE GEAR |
| Author: | higgy [ Thu Jun 10, 2021 10:33 am ] |
For the more adventurous among us: ---) these guys have interesting conversations but seem to be perpetually sold out or in production and almost all they do is much cheaper some where else |
