| Paso Fairing Fittings - Well Nuts http://ducatipaso.org/forum/viewtopic.php?f=1&t=8429 |
| Author: | murphus [ Sat Oct 09, 2021 5:59 pm ] |
| Post subject: | Paso Fairing Fittings - Well Nuts |
Does anybody know where I can get the correct well nuts to secure the side panels to the gas tank on my '88 Paso? They're smaller than currently available "standard" 6mm well nuts, which seem to come in at around 12.5 to 12.7mm; the fixing holes in the gas tank are approx. 10.5 to 11mm. |
| Author: | higgy [ Sun Oct 10, 2021 7:17 am ] |
| Post subject: | Re: Paso Fairing Fittings - Well Nuts |
I have in the past found them at HomeDepot,MSC Direct or McMaster Carr.Any larger industrial supply company should have a wide range available |
| Author: | murphus [ Mon Oct 11, 2021 12:16 am ] |
I can find 6mm well nuts no problem, but they're all made for a larger hole size and won't fit fixing points on the gas tank. At least the one I got will not compress enough to fit. It appears it needs to fit an 11mm hole, not a 12.5 as most of what I'm finding is specified for. |
| Author: | higgy [ Mon Oct 11, 2021 7:19 am ] |
try MSC or McMasterCarr or fix the holes
| Author: | Witzie [ Wed Oct 13, 2021 12:56 pm ] |
i use the same plugs on all fittings on my 906 but also on the 750 i had. So fix the holes like Higgy wrote. |
| Author: | murphus [ Tue Oct 19, 2021 7:58 pm ] |
I found some 12mm well nuts at an outfit in Ohio. A little grease and they fit nicely. https://zspecdesign.com/m6-rubber-compo ... -10-packs/ |
