ducatipaso.org • View topic - Dellorto Carbs....Again
It is currently Sun Mar 01, 2026 8:44 am
 Post subject: Dellorto Carbs....Again
PostPosted: Fri Dec 30, 2005 2:48 pm
PostPosted: Fri Dec 30, 2005 6:32 pm
PostPosted: Fri Dec 30, 2005 6:49 pm
PostPosted: Sat Dec 31, 2005 3:34 am
Pull the slides it is then. I'm riding Sunday (New Years tradition) so I might try to get it fixed tomorrow, otherwise it will be yet another project for later in the winter.
I can get parts for the Dell's here so maybe I'll just order 2 new slides and throw them in.
PostPosted: Sat Dec 31, 2005 4:56 am
:thumbup:
Good stuff, Jon. And I strongly recommend that your last check is my 'Ducati cuddle' slide synchronization to within 4 thou of slide movement or better, if possible. Four thou movement of a slide probably equals at least 200 rpm.
Probably the cables will need very careful attention to ensure things are going to stay right once you get them right.
PostPosted: Tue Jan 03, 2006 4:32 pm
PostPosted: Wed Jan 04, 2006 12:36 pm
PostPosted: Wed Jan 04, 2006 12:49 pm
PostPosted: Wed Jan 04, 2006 1:56 pm
-Craig
PostPosted: Wed Jan 04, 2006 5:29 pm
