ducatipaso.org • View topic - oil temp guage?
It is currently Thu Mar 05, 2026 10:58 pm
 Post subject: oil temp guage?
PostPosted: Tue Feb 21, 2006 10:32 pm
Hey there paso freaks, Im new to the site and must say this is great, had I known that such a resource existed, I would probably saved and unfathomable amount of time and $, not to mention all the swearing and punching of inanimate objects. Anyway, The last few times I had the Paso out the oil temp guage hasent come up even after reaching norm. operating temp. I've covered all the bases i.e. connections, corrosion, etc with no luck, any suggestions, thanks, Chris
88 750 PASO
78 CB 750 CAFE I know- Iknow....the lady friend usually rides it
PostPosted: Wed Feb 22, 2006 1:29 am
There are 2 connections on for the center post and 1 for the ground. It need to be grounded properly for it to work because it's mounted in rubber. Mine stopped working so I replaced it. I think it was 4-5 bucks at the local auto zone.
I will add that the oil stays quite cold in the winter time. The needle never moves until May here in NY.
 Post subject: Re: oil temp guage?
PostPosted: Wed Feb 22, 2006 11:41 am
PostPosted: Thu Feb 23, 2006 9:49 pm
Thanks for the insight! Turns out it wasn't grounded properly, I was able to get a decent ride in today and the guage is back in buisness! Now if we could just get the street sweepers out to clean up the gravel coated back roads of Colorado!
