ducatipaso.org • View topic - Problems for starting the paso ...
It is currently Mon Sep 29, 2025 11:59 am
 Post subject: Problems for starting the paso ...
PostPosted: Tue Feb 14, 2006 10:32 am
Hi all,
I have got some problems with the starter. When I push the red button I hear the starter spinning, but it doenst move the engine. After some tries it moves and the engine starts. I suppose there will be a "one way bearing" or something similar.
It is frustating pushing and pushing the starting in the morning ... and it is going to worst :sad:
Regards
PostPosted: Tue Feb 14, 2006 12:28 pm
You have a sprag clutch spring problem. Go to first topic on 750 forum, which is "stickyed", By Jon Slocum. Halfway through first post is topic"sprag clutch". there is your problem and cure.
PostPosted: Tue Feb 14, 2006 12:53 pm
I have heard, that this sprag clutch problem is very often in many Ducatis.... Need to open left cover and take flywheel out. I have to fix it also soon in my 750 Paso :sad:
PostPosted: Tue Feb 14, 2006 1:16 pm
Not really a hard job if you have an impact wrench for flywheel nut. Should be easier on 750 than my 907 as there is no cooling system to deal with. Just be sure to keep track of which way is out on clutch and do not remove rollers. Just shorten spring and replace.
PostPosted: Tue Feb 14, 2006 3:16 pm
Ok, will try finding an impact wrench for flywheel nut and some time for the operation ....
Thanks !!
PostPosted: Wed Feb 15, 2006 3:29 am
Is this a sudden problem or have you been dealing with it for a while?
Make sure that battery is fully charged.
Did this problem start after an oil change? A new type or weight of oil?
Let us know.
PostPosted: Wed Feb 15, 2006 8:20 am
PostPosted: Wed Feb 15, 2006 5:33 pm
PostPosted: Fri Feb 24, 2006 8:59 am
Users browsing this forum: No registered users and 104 guests
