| Oil on cooling fins http://ducatipaso.org/forum/viewtopic.php?f=1&t=925 |
| Author: | pasophist [ Sun Mar 05, 2006 3:53 am ] |
| Post subject: | Oil on cooling fins |
Hi Guys. I found one of those little black miniature pucks on my garage floor with a dollop of oil on it. I discovered then that the "puck" is supposed to reside between the fins on the cylinder heads- presumably to stop them from vibrating. On close examination, I found oil on several of the fins, notably close to the spark plug location. But I have not been able to locate a source of the oil. Any ideas? Thanks in advance. Perhaps copy replies to smseigel@shaw.ca |
| Author: | cagiva905 [ Sun Mar 05, 2006 8:52 am ] |
| Post subject: | |
If we are talking about the rear cylinder, on 900 heads there is a small blindplug just behind the spark plug hole. This blind plug often is a small cause of oil leakage. perhaps this plug is also on 750 heads? Michiel |
| Author: | pasophist [ Sun Mar 05, 2006 8:02 pm ] |
| Post subject: | |
| Author: | DesmoDog [ Mon Mar 06, 2006 3:35 am ] |
| Post subject: | |
If it's what I'm thinking of, it blanks off an oil passageway that is machined in after the head is cast. As in they drill a hole to allow oil to flow in the head, and then cap the end so it doesn't leak.. which it ends up doing anyway... |
| Author: | pasophist [ Mon Mar 06, 2006 4:49 am ] |
| Post subject: | |
