ducatipaso.org • View topic - Wanted !! Dual Carbs, Manifolds & Cables For Paso Conver
It is currently Tue Jun 16, 2026 5:59 am
 Post subject: Wanted !! Dual Carbs, Manifolds & Cables For Paso Conver
PostPosted: Mon Mar 20, 2006 8:04 pm
Hi,
Looking for a set of carbs,mainfolds and linkage to do a conversion swap on my 88 paso. I have been told that any dual carb setup off of a 90's ss750 or ss900 will do the trick and that some monster carbs will also work.
Jeff
PostPosted: Mon Mar 20, 2006 9:13 pm
Whoa, you wanna do some research, you do! I've got a set of Mikuni's from my 900ss, and I wouldn't wish them on my worst enemy! I've got dellortos on my 900ss and Paso now, and I can't honestly recommend them for the 900ss; (has something with watching my bike burn to the ground on pit lane at Mid Ohio-but the battery acid from the explosion, and the PKP from the fire extinguishers was the worst).
But the PHF 36's I have in the Paso have metal float tabs, so hopefully no Duck Flambe' because of them.
PostPosted: Wed Mar 22, 2006 3:22 am
