I thought the same thing, but it won't work unless you do some further modifications to the inside of the tank. I tried doing the same thing a few years back. If you simply remove the fuel pump, filter and hoses in the tank, the pickup in the tank is half way up the tank, and you will "run out of gas" with a half a tank of gas still in the tank. In my bike, the steel lines are brazed into the tank. Knowing Ducati at the time, there may be quite a bit of differences between bikes, so your bike may be different.
That being said, you may want to check out everything in the tank. There is a filter, and if its clogged, the fuel pump may be working too hard and shutting down. Fuel pumps are generally thermally protected, for obvious reasons. You may have just reset it when you stopped and went to tap on the pump. The wires to the pump may be intermittent, or loose. They are held on with very small nuts, I think 3 or 4mm as I remember. The hoses also have some problems as they degrade over time, and may be sending small pieces into your fuel pump. Bits of rust will also create problems in your pump. Make sure the prefilter sock is still good. When replacing your tubing, always buy tubing for fuel injection, and use F.I clamps, as it is a higher standard tubing and less prone to degradation while sitting in fuel all its life, and the clamps offer better distribution of force without chewing up your tubing. If you use gasahol, be aware that the alcohol will disolve any spare paint in the tank, and that too will clog your pump or filter. ( voice of experience here). Also check your electrical connections to the tank. As with all bikes, clean all the connectors and put some silicone dielectric grease on the connectors.
ST's have had problems with the tubing just degrading to the point that it won't hold pressure anymore, and the bike dies. $1.00 worth of good tubing, and your are back on the road.
Another thing to check is that huge petcock. If that has some obstruction, then the fuel pump may be working too hard. I removed my petcock and replaced it with a banjo bolt and fitting. Its a 10mmx 1.0 thread into the tank. I didn't see the need for a petcock with a fuel pump in the system. I will be adding a vacuum petcock from a Monster just for my peace of mind, but I've never flooded the bike in the past 5 years.
Of course, there is always the possiblity that your pump has just flat died.
If you can get into the tank to cut off the steel lines, then gravity will easily do its job to feed your Dells. Be careful of sparks, even after you rinse it with water and thoroughly dry it. I couldn't find a graceful way to do this, so I just rebuilt what I had, and everything worked out just fine.
