ducatipaso.org • View topic - Piston Rings
It is currently Sun Sep 28, 2025 3:21 am
 Post subject: Piston Rings
PostPosted: Thu Aug 06, 2009 1:09 am
Hi Guys
just interested to find out if rings are easily available your side of the world.
I was one afternoon away from completing the rebuild of my motor and managed to break the one oil ring - #$%&*&^* -!! But here in New Zealand not available nor in Australia. So Gowanloch Ducati in Sydney (quite a famous place to source old Ducati stuff for those who haven't heard about of them before) have had to order from Italy at $AUS 175.00 per set. Is going to take 2-3 weeks.
How does that compare with the States or Europe?
Cheers Clive
Clive
 Post subject: Re: Piston Rings
PostPosted: Thu Aug 06, 2009 2:27 am
Just bought rings here in the USA for my F1. They were in stock at BCM Ducati in New Hampshire and they cost $106 delivered to me in NY.
PostPosted: Thu Aug 06, 2009 2:36 am
Jon
is that per set or for both? Does the F1 have 3 rings - 2 compression and 1 oil?
There is a guy here who races an F1 and "i'm told" runs Nissan pistons in it. Have you ever heard of alternative pistons fitting 750 Ducatis before?
Cheers Clive
Clive
PostPosted: Thu Aug 06, 2009 8:42 pm
Yes the F1 has threee rings in a set. That was just for 1 set. Ducati gets big $$ for piston rings....
There are alternatives to Ducai pistons but I have never heard of a Nissan piston. If the dimensions are right then why not?? I can't imagine that they would be better than Pistal or some other real aftermarket high end pistons. Check out California cycle works online.
PostPosted: Mon Sep 21, 2009 7:12 am
Clive, I'm guessing you have fixed this prob but for others there are alternatives.
Dodge Neon/Mitsubishi Eclipse rings are as cheap as (an you get 2 sets) for $93 US landed in NZ
They are 88mm x 1.2 - same as Ducati - you have to get the grooves made deeper but overall its the cheaper option.
Mine are awesome- most compression/ lowest oil comsumption I have had for 9 years !
Tony
PostPosted: Thu Dec 24, 2009 6:48 pm
some one ebay
http://cgi.ebay.com/DUCATI-750F1-RINGS- ... 45effbbf02
PostPosted: Fri Dec 25, 2009 9:41 am
I'll have a look, I may have some here in Sydney.
PostPosted: Fri Jan 01, 2010 10:25 am
I have two 750 Paso pistons new complete with rings, pins and circlips if anyone is interested. Location Sydney, Australia
