It is currently Sat Jun 13, 2026 7:58 pm
 Post subject: Rare C/S sprocket
PostPosted: Wed Sep 07, 2011 2:26 am
Not mine, nor do I know the seller.
http://cgi.ebay.com/ebaymotors/Cagiva-D ... _500wt_956
Giant offset front sprocket for early models that didn't have the 3mm shims between the motor and the frame on the right side. Also good for running 180 -16" rear tires. Check your chainline if you buy it.
 Post subject: Re: Rare C/S sprocket
PostPosted: Wed Sep 07, 2011 7:40 am
I had one of those and the offset is way more than required even with a 180 tire. At least on a Paso 750 that is.
They are not that rare btw. I ordered a new one from
http://www.motorrad-tuning-zubehoer-tei ... j.-1987-na
Getting it was no problem. They have them in 14 an 15 teeth. Price is €32-34 ($45-49).
