It is currently Thu Jun 18, 2026 4:55 am
[ 3 posts ] |
| Author |
q10115
Post subject: Carburetor synchronization tuning Posted: Thu Jun 18, 2020 6:05 am |
Joined: Mon Aug 26, 2019 4:29 pm Posts: 18 Location: USA
What RPM do you folks generally synch the carbs at? Idle? 3,000 RPM? 5,000 RPM? I feel a bit of a buzz at the higher RPMs and want to know if throttle balancing could smooth it out.
Thanks, Roger
| Top |
Frank.61
Post subject: Re: Carburetor synchronization tuning Posted: Thu Jun 18, 2020 8:25 am |
Joined: Fri Jul 24, 2015 11:21 am Posts: 261 Location: Belgium
Hi Roger,
Stationairy/idle, it should run as slow as possible (you want to make sure they open the butterfly valves the same amount, hence: synchronisation). The engine needs to run just on the idle jets! Make sure everything else like valve play, new air filter, ignition timing or new spark plugs etc. have been taken care of in advance (synchronizing ist always the very last thing in tuning/adjusting after maintenance).
Buzz at higher rpm is most likely something else.
Good luck!
_________________ Bimota SB4-S - 1984 Ducati Paso 750 - 1989 Suzuki SV1000S - 2008 Ducati Monster 796 abs - 2010
| Top |
Frank.61
Post subject: Re: Carburetor synchronization tuning Posted: Thu Jun 18, 2020 8:38 am |
guys,
Before anyone is bothered: this is the short version. Synchronization, the how, in practice depends on carburettor/injection construction and the number of cylinders. In short, it boils down to the fine adjustment either on the throttle valve adjustment (mechanical) or also via the idle mixture jets (e.g. at the Weber where the butterfly valves are fixed on one shaft). just for the record ....
| Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 7 guests |
