It is currently Sat Apr 11, 2026 7:47 am
 Post subject: Rear brake pump leaking - 750 Sport
PostPosted: Mon Sep 06, 2021 7:56 pm
My 750 Sport is leaking from the rear brake pump.
Easily fixed with the 0664339732 replacing set. But that seems to be long gone. Same with a complete pump 066441300.
My ducati dealer suggest I could try a later pump 62540041A, but they have the brake line from the side/top, not from the end as my original pump.
I would appreciate any help/link etc to the correct replacement part, if that is a replacement set or a complete pump.
 Post subject: Re: Rear brake pump leaking - 750 Sport
PostPosted: Tue Sep 07, 2021 10:19 am
Your dealer is suggesting a brake pump with 40mm mounting hole distance to replace one with 50mm?
I'm not sure if the original was a PS11 or 12, but Stein Dinse has the first:
https://www.stein-dinse.biz/product_inf ... rettyPhoto
