750 Sport Riders and Owners http://ducatipaso.org/forum/viewtopic.php?f=13&t=2061 |
Page 1 of 2 |
Author: | Underblog [ Sat Oct 27, 2007 9:18 pm ] |
Post subject: | 750 Sport Riders and Owners |
Author: | ducapaso [ Sun Oct 28, 2007 8:14 am ] |
Post subject: | |
weber carbs require a correct setup to run smoothly (and it's not so easy to do!) and the behave of the engine remain still harder than a mikuni carbed engine, but weber perform a bit more. 16" inches rims require tires hard to find and not so performing than newer 17" tires ( last production of a59 front tires is dated 2004; rear m59 are earlier) The end, if you don't like do-it-yourself maintenance, vintage ducs are not fitted for you, but if you feel like loosing you time debugging troubleson your beloved wheeled girlfriend... :thumbup: |
Author: | Finnpaso [ Sun Oct 28, 2007 7:40 pm ] |
Post subject: | |
Author: | Finnpaso [ Sun Oct 28, 2007 7:43 pm ] |
Post subject: | Re: 750 Sport Riders and Owners |
Author: | ducapaso [ Mon Oct 29, 2007 9:29 pm ] |
Post subject: | |
I just was told that switching to mikunis should have given me less power but an easier handling from the engine |
Author: | Finnpaso [ Tue Oct 30, 2007 1:22 pm ] |
Post subject: | |
I dont belive to such stories, if there are not any evidences, like dyno runs, etc.... Surely 750 Supersport engine(with Mikunis) gives less power, cause those have totally different cams, but i think, Mikunis can handle better fuel, than Weber, what is designed for cars.... |
Author: | ducapaso [ Tue Oct 30, 2007 5:09 pm ] |
Post subject: | |
Author: | Underblog [ Tue Nov 13, 2007 12:13 am ] |
Post subject: | New 750 Sport Owner |
Author: | jcslocum [ Tue Nov 13, 2007 2:06 am ] |
Post subject: | |
Eric, Your clutch and gear box/shifting issue will probably be fixed by a real good clutch bleeding. Thes clutches are a bitch to bleed right and a vacuum bleeder will be a big help. There may be some rust or corrosion on the plates so some riding may clean that up. |
Author: | paso750 [ Sat Nov 17, 2007 8:54 am ] |
Eric, check the P750 forum. You`ll find a thread with "downloads". In it you will find the workshop manual for the 750 Sport. G. |
Author: | Underblog [ Sat Nov 17, 2007 2:29 pm ] |
G I looked in the P750 forum and the newly reconstituted docs.ducatipaso.org folder and could not find the manual. Can you provide a link? I thank you in advance. BTW, took the 750 Sport to work and back. What a fun little bike! Less civilized than the 851 (harder to shift, Mikuni's sputter a little) but excellent when warm and at speed. |
Author: | mike [ Sat Nov 17, 2007 4:29 pm ] |
take note! we have a 750 Sport forum category now! ![]() |
Author: | paso750 [ Sat Nov 17, 2007 4:48 pm ] |
the thread is on the first page of the P750 forum ![]() here the direct link: viewtopic.php?f=1&t=1551 (Mike, will the Sport section remain ? It existed already longer time ago and then was removed. For me that`s fine ... I`m just asking) G. |
Author: | mike [ Sat Nov 17, 2007 6:58 pm ] |
yes the Sport section shall remain. I removed it so long ago because someone was trying to start up a Sport site and I did it as a courtesy to help them kickstart their page. I've not seen much activity outside of this group with respect to the 750 Sport, so we are going to adopt them back. |
Author: | Underblog [ Sat Nov 17, 2007 7:56 pm ] |
G Thank you for the link. Found the manual links, opened up Windows on my Mac, and unzipped the files. Thank you much! I tried without success to check out the new 750 Sport Forum. I was told I did not have the correct permissions ![]() |
Page 1 of 2 | All times are UTC |
