| 750 sport rear seat cover http://ducatipaso.org/forum/viewtopic.php?f=13&t=2836 |
| Author: | Competizione [ Sun Oct 19, 2008 2:58 am ] |
| Post subject: | 750 sport rear seat cover |
Hey Guys, Been putting my 750 back together. Got the original pipes and seat back on, but I am still looking for the original rear seat cover. It still has the Weber on it. Need to find info on changing the fuel pump. Any info would be helpful. I'll post some pics as soon as I figure out how to do that. Competizione |
| Author: | jcslocum [ Sun Oct 19, 2008 5:32 pm ] |
| Post subject: | Re: 750 sport rear seat cover |
The feul pump is inside the tank. You take off the filler to removed it and change the filer. |
| Author: | Manxman [ Mon Oct 20, 2008 2:54 pm ] |
Hi there, what do you mean "changing the fuel pump"? I succeeded in "improving" the fuel pump by changing to another pump and I would strongly recommend it since on my bike it has removed all "socalled" problems of the Weber carb. It runs perfect now! I am now using a membrane pump from a Yamaha. Need more infos? Let me know.... Or if you understand some german, look at http://www.mutantmarine.de (few pics). Ciao Felix |
| Author: | blaster [ Tue Oct 21, 2008 3:47 am ] |
hi. if you are having carb problems because of high fuel pressure which i hear causes some of the problems with the webber. i think there is a way to adjust the fuel pressure though i have never done it because i replaced my webber with mikunis in 1994 and i had no pressure problems. in the fuel return line that goes from the main line to the return spiggot under the tank there is a main jet pushed into the fuel line about half way in. i think you can adjust the fuel pressure by "jetting" the fuel line. simple and clever if it works. i also think the 750 paso has the same setup but i can't remember. if anybody out there has any experence with this post it. blaster |
| Author: | jetboy [ Sat Nov 08, 2008 4:25 am ] |
did you ever find a source for the rear seat cover? im also in need- |
| Author: | blaster [ Sun Nov 09, 2008 4:46 am ] |
hi if you guys are refering to the rear seat cowl i have three but i am keeping two. all of them have the same problem when you use them for very long. the mounting tabs that slip into the bodywork have broken off and the small pad has worn thru on the top edge. the broken tabs aren't a big problem thought, the cowl just sticks up a little. i would sell one of them if you want it. the surface and paint are fine, maybe a scrach or two. make me an offer. blaster |
| Author: | jetboy [ Sun Nov 09, 2008 9:16 am ] |
dont want to hijack his request - so ill give comp a chance first. plus i contacted someone else yesterday who has one, and he needed me to wait a week and i said i would, so-- i should wait. but if no one else is interested, i may be depending on the other deal. that little cowl really completes the look and id love to get one. |
| Author: | ducinthebay [ Sun Nov 16, 2008 1:25 am ] |
I have never seen one of those seat covers/cowl with the tabs still in place. They all break off. If you are going to repaint it, I would suggest making nice piece of aluminum to simulate the tabs and mount it with some nice round head screws. Its one of those design flaws that didn't quite get figured out before launch. You had to remove the seat cowl to remove the seat. Of course the anxious owners didn't quite get the memo, and a quick yank on the seat after turning the key broke the tabs. It was a silly design to require the owner to find an allen key and remove the cowl before removing the seat to get to the otherwise well designed glove box. All this talk about the seat cowl has me thinking that I might try to refit the beat up one I have, but attach it to only the seat so it comes off together. Mine came with two different size pads. Did my P.O. make those, or does anyone else have two different size pads? Cheers, |
| Author: | blaster [ Mon Nov 17, 2008 3:33 am ] |
i have never seen two different sized pads before and like i said ,i have three cowls. one good thing about the tabs being broken off is that you don't have to remove the cowl to pull off the seat though the cowl does stick up a little. i still have one for sale if anybody wants one. blaster |
| Author: | masijim [ Fri Nov 21, 2008 4:51 pm ] |
I'm in need of a rear seat cowl for an F1. What I need looks the same as the Sport, but I'm not sure if they're the same. Do you know if they're the same ? If so, I definitely want it. |
| Author: | jetboy [ Sat Nov 22, 2008 12:13 am ] |
i was also set to buy but ive been told that my seat is not stock so it probably wont fit unless i get a whole new seat etc. |
| Author: | blaster [ Sat Nov 22, 2008 5:46 am ] |
jetboy, yea, i looked at the pictures you posted. not stock. masijim, i don't know if it will fit an f1. i'll ask around and post it. blaster |
