ducatipaso.org • View topic - 750S vs. 750 Paso Exhausts
It is currently Mon Sep 29, 2025 1:52 am
 Post subject: 750S vs. 750 Paso Exhausts
PostPosted: Wed Mar 11, 2009 10:16 pm
Hello All,
Does anybody know whether the standard 750 Sport and 750 Paso exhausts (not the headers) are the same? They seem to be identical but you never know...
Mark
 Post subject: Re: 750S vs. 750 Paso Exhausts
PostPosted: Thu Mar 12, 2009 5:00 am
If you search through the posts, you get a more clear answer than mine, but the short answer is no, they are not the same. The look identical, but the attachment of the silencers to the header pipes is different and they don't interchange. However, if you get the entire Paso system, it would probably fit onto a Sport.
The Sport's header system is identical, at least in appearance, to the later SS and Monster series. So I would imagine that those pipes will fit right on.
You can also put on pipes from a 900 motor I believe, you just have to trim the rear pipe where it fits into the collector.
PostPosted: Tue Apr 14, 2009 7:38 pm
I do not see why not, just about everything else except the bodywork is interchangable. Also, have you given thought to 91-98 SuperSport Exhaust. Here is a pic of mine with exhaust from a 95 900SS.
