It is currently Sat Jun 13, 2026 11:54 pm
 Post subject: Fitting 900SS headers to a 750 Sport
PostPosted: Fri Apr 17, 2009 4:35 pm
Hi all
I purchased a nice set of 1995 900 SS headers the other day after having found out they will fit my 1990 750 Sport. The headers came with the retainers and I noticed that the retainer are a slide fit over the flanged end of the header. Am I missing some sort of shim that holds the header tight to the head, if so does anybody know where i can buy them? Thanks.
 Post subject: Re: Fitting 900SS headers to a 750 Sport
PostPosted: Fri Apr 17, 2009 5:22 pm
Yeah, there are two steel half shell type of things that you need for each pipe. this was a change in later models and allowed things to move a bit more without creating exhaust leaks. You need a total of 4 of them. They fit around the pipe and touch off on the flange on the pipe and the retaining collar.
PostPosted: Fri Apr 17, 2009 11:16 pm
And closest to heads, there is a copper gasket.
PostPosted: Sat Apr 18, 2009 11:16 am
Thanks guys. Any ideas as to where they can be found?
