Jon - it only seemed like 4 hours!
This is my first post, but I've been lurking for a while. I just picked up a '90 Sport, and today was my first day to do more than look at it. Registered it, cleaned it, replaced some bad bolts and wellnuts, and noticed some horrible wiring from the alternator, which makes this thread very timely.
I cut about six inches of horrid-looking wires off the yellowish/brown wires between the alternator and RR. Plenty of slack there, so this wasn't a big deal. I noticed the unused red wire, too. Can anyone shed a light on what and why this is? The shop manual shows a photo with three wires, but that's about all it says. The two yellow wires appear to be aluminum, which I didn't expect.
This bike, a relatively low mileage example (under 15K) has two regulator/rectifiers. The OEM one under the seat is disconnected, and there's a replacement in front of the battery. A much better location for airflow, for sure, but I'm amused no one ever chucked the old one.
I went on two brief 8 mile jaunts today (to a friend's for dinner and back a few hours later). To and fro, the red battery idiot light never went off, so I need to do some more diagnostics on the system...check today's patch job, check the AC voltage out of the alternator, and check the DC voltage out of the RR. Battery was 12.7v when I left, and that was sitting for ~10 days without a charger. I didn't check it when I returned.
Like Jon said before, we were getting 70 v AC at 4000 rpm off a 916 (350 watts) last weekend, and my '92 750SS was also in that range when I tested it last year. My SS has the same 300w alternator as the Sport, so I expect this bike to generate about the same. I'll post my results tomorrow, assuming I get back to it.
Thanks.
Ben
