| Greetings and some questions http://ducatipaso.org/forum/viewtopic.php?f=13&t=3334 |
| Author: | DUC750s89 [ Tue May 19, 2009 8:35 am ] |
| Post subject: | Greetings and some questions |
Hi im the proud owner of a heavy modified 750s 1989, and have som issus id like to adress on it. First what are the dimension of the oilcooler lines ( and can i bay those at any leanght ?) Im a newbie my first DUC. I need a link to filters KN if possible for the weber44. And the last and for me importent issue any manuals an info PDF ?? Im sorry for the english writing, but i hope it can be read :-) |
| Author: | Tamburinifan [ Tue May 19, 2009 10:59 am ] |
| Post subject: | Re: Greetings and some questions |
Welcome! Workshop manual here: http://ducatipaso.org/docs/sport/Worksh ... _Sport.zip Where are you located (please fill in profile)? |
| Author: | jcslocum [ Tue May 19, 2009 11:12 am ] |
| Author: | jetboy [ Tue May 19, 2009 10:57 pm ] |
If you want to not go stock: you can use the fittings from later SS and monster oil coolers if you swap out the nipples at the engine case. the smaller diameter nipples screw right as a direct replacement to the sport- $17 a piece from the dealer, or get some off an old ss engine like i did. I am not sure if you can do the same to the oil cooler itself, as i just used an SS oil cooler as it already had the correct fittings. I offer this because it gives the option to use stainless steel lines from many of the later model bikes-- and you could probably get some made if none of them are long enough. |
| Author: | 289cdo [ Wed May 20, 2009 10:36 pm ] |
hi their i have a k/n filter on my 750 sport. the part number is:k/n 56-1120. hope this helps |
