It is currently Sun Sep 28, 2025 12:31 pm
 Post subject: chain and sprockets
PostPosted: Sun Jul 26, 2009 7:56 pm
Hi,
I've just aquired a 750 sport ('92), which is a 88-89 model. I've wanted this bike for a long time!!!
I'm a bit puzzled by the chain and sprockets installed on the Sport. The sprocket on the engine has been made in such a way that it is mounted on the very end of the splined engine axle and fixed with one central bolt. If I take a look at the 750 sport documents and even at the 750 paso I see a different system where the sprocket is installed futher down the axle (towards the engine) and bolted down with two bolts and a little plate. (like my 650 elefant).
I have trouble seeing if the sprockets line up. Which is the right system?
Joep
 Post subject: Re: chain and sprockets
PostPosted: Mon Jul 27, 2009 11:25 am
Hi,
Got the anwser some posts down. Apparently there are two systems and frames and so on.
Cheers Joep
