ducatipaso.org
http://ducatipaso.org/forum/
Tacho drive off the Cam shaft info
http://ducatipaso.org/forum/viewtopic.php?f=13&t=3533
Author:  Mustang505 [ Mon Jul 27, 2009 11:43 pm ]
Post subject:  Tacho drive off the Cam shaft info
Hi all
Not sure if anyone has info on this as the workshop manual shows very little to nothing.
It states that the cam shatf that drives the tacho has two key ways - one for the belt dive and one for the tacho worm gear. Both my cam shafts have only one key way and the worm gear does not have a keyed slot in it anyway. Not sure why this is different - does anyone know?
thanks Clive
Author:  Speedmade [ Sat Aug 01, 2009 3:29 pm ]
Post subject:  Re: Tacho drive off the Cam shaft info
There is no keyway for the tach gear. Once the cam pulley nut is torqued up the tach gear is clamped in place.
There is very little force applied by the tach and cable to require a keyway to hold the gear in position.
Author:  Mustang505 [ Sun Aug 02, 2009 9:03 pm ]
Cheers thanks for the confirmation.
Clive
Page 1 of 1 All times are UTC
http://www.phpbb.com/
